I recently bought a few Cardas shorting straps. Can I use this to short Pin 2 and 3 on the XLR input of the DAC? Could it potentially cause a problem?
It won’t hurt the DAC. It may make the sound quality better or worse, try it both ways.
Ted, thanks for the fast response!
Listening to it now. I think it did make a bit improvement.
Ted, can you please confirm that Pins 2 and 3 should be shorted, and not Pins 1 and 3? Reading through various forums, it seems that most equipment calls for Pins 1 and 3.
The signal is between pins 2 and 3. Shorting only one of 2 and 3 to the ground pin (pin 1) won’t keep noise out of the system.
Thanks, Ted. That was my thinking also, so I was confused why so many others said 1 and 3.
