USB from PWD II to Mac mini not seen, please help?
@pixelplay can you please be a bit more specific. What has changed in your system? What player are you using? Which piece of equipment is not showing the USB connection?
firmware 2.03 to a mac mini running 10.7.5. The Mac fails to see the PWD.
Updated PDW to 2.1 and it is seen. I am hoping that the latest 2.4.1 will do the trick as I prefer the 2.03 sound.
I believe there were some changes to the firmware going from 2.03 to 2.1 that influenced USB. All subsequent firmware s, including 2.41 should be fine.
Mine does not work either. Strange, as it always has before.
Driver is visible on the Mac and PWD makes a click and a whistle when I select the USB input.
Dennis, perhaps this is another clue? to the tuning sounds? [whistles]
Gordon, what firmware are you currently running, 2.4.1?
@elk
2.4.0
I then select PC/MAC output as the USB
When I hit play it plays on JR or EMM and when I select the PWD?USB input I hear a click [responding] but no sound.
I don’t use USB much but this sudden loss of it baffles me.
In JR I cannot see the usb output as a zone
“Baby, I’m Amazed”.
Last night I decided to take my own medecine and turn EVERYTHING OFF and unplugged, also reset and restarted all including the espresso machine and the toaster.
I now have USB via JR and EMM.
I wish I could claim credit for the victory but I think it was more a “cosmic” energy intervention.
Now, if it would cure the pops and tuning sounds I would be in Audio Nirvana.
Thanks to elk for prompting me to try it again.
This is a relief. If USB disappeared this would be a major bug.
