DESCRIPTION
"Roonify" your DLNA/UPNP devices. The SonoreUPnP Bridge allows you to use Roon or Roon / Tidal to stream to the PS Audio Bridge and other DLNA/UPNP devices. You can also use Logitech Media Server to stream to the PS Audio Bridge and other DLNA/UPNP devices..
SPECIFICATION
- Gapless playback with Roon Server
- Gapless playback with Logitech Media Server
- Selectable final stream types - LPCM or WAV
- Selectable maximum stream sample rate
- File Formats - typical file formats supported by the server
- Transmission from server to Sonicorbiter is Squeezebox protocol
- Transmission from Sonicorbiter to DLNA/UPNP device is UPNP protocol
- PCM Sample Rates with Roon Server - up to 192kHz PCM
- DSD Sample Rates with Roon Server - DSD64 via DoP, DSD128 converted to PCM
- PCM Sample Rates with Logitech Media Server 7.9 - up to 384kHz (Sonicorbiter)
- DSD Sample Rates with Logitech Media Server 7.9 - up to DSD128, DoP is not supported
AVAILABILITY
The SonoreUPNP Bridge application is available on the following hardware:
Sonicorbiter SE, microRendu, microJukebox, and sonicTransporter series
LICENSING
Copyright © Simple Design, LLC
Click here for additional information:
SonoreUPnP Bridge
