Sprout has been stripped from the website?
I’m not finding any Sprout stuff at all on the website. Not in manuals, not in the store, nothing. Did PS sunset that product?
If so, I bet it was because it got too expensive to make and sell. A casualty of new tariffs, and overall price hikes.
But I disagree with removing all history of it from the website. They’re still out there and not out-of-date! They are great little systems.
after more digging, I also eventually found the manual. Thanks @Palouse
Maybe there are plans for Sprout…
www.sprouthifi.com
Did you look in the manuals section of the website: https://www.psaudio.com/pages/manuals
Sprout and Sprout 100 are both there if you scroll down the page.
Sprout is a great little integrated amplifier and my son, Scott, is going to take it over and develop a new one sometime next year. www.sprouthifi.com
Thanks @Paul! Exciting to see something is happening with that little guy. Most of my friend know about the Sprout over here because we use it for our little systems, desktop setups, kitchens, small rooms. PS Audio is in a handful of houses Because of this little guy.
Exciting to see what’s up next for this product line.
Great idea.
Impressed with your family’s efforts at innovation…
Good luck to you and @scottm with the new venture.
I like the sound of ScottMcGowanhifi.com
The Sprout100 is one of those forever pieces in my collection. Scott McGowan really nailed it with this one—pound for pound, it’s the best in its class and always punches way above its weight. With the vision behind it, I’m confident future versions will only raise the bar even higher.”
Thanks. We’re so proud of Scott. It’s a big deal the venture out on your own and I cannot think of anyone better suited and prepped than Scott. I can’t wait until he launches the new Sprout. He’s got some wicked cool innovations he’s launching with it. Appreciate the kind words and support.
Thanks all! I will be making a more public announcement soon, but I caught this thread and I wanted to say I really appreciate the kind words :slight_smile: I will never forget my roots at PS Audio and my experience there will help me every day in my new venture. And the support from our dedicated followers makes all the difference. Thanks again!
