Which do you read?
NYt, WSJ, FT.
I don’t know what is inside but when you hold the box and shake it it feels like there is some sort of sympathetic/rubbery sort of diaphragm in the box.
I was wondering if the larger the listening room the less effective the Black Box or any other bass treatment would be. The fact that your smaller sized footprint hints at only needing one seems contrary to the larger room needing less thesis. Or maybe your relative room dimensions produce a flattish room resonance in the bass area.
I get the idea of some type of sympathetic resonator help to control bass reproduction. I have issue with how small the box is and how that tiny thing can do anything effective against large bass wave fronts. Listening to the designer explain some of his creations I get the feeling he is a charlatin.
Happy cake day! ![]()
The black box basically sounds like what the ASC subtrap does by eliminating bass boom.
I have heard the Black Box in a much larger room than mine at @paul172. Both rooms have nasty room nodes and increase or cancel as you move in the room. Both rooms benefited from a single BB. There seems to be no correlation with room size and number of BB’s, but YMMV.
The ATC is totally passive…tuned fiberglass in an enclosure. The Black Box seems to be active…
a mechanical sympathetic resonator. The results might be the same but the methodology is different.
I currently have 4 3ft x16 inch and 2 4ft x 16 inch Isothermal Tube Traps. They are quite effective. However I want to try two black boxes to compare. The footprint is smaller.
It could be finished room vs unfinished rooms. Both @aangen and @straightwire have finished rooms with drywall I don’t have finished walls or ceilings.
The unfinished ceiling actually is a better diffuser/absorber than finished. Not sure if that matters with large bass waves but it does make a large difference with mid and small frequency
I was saying that might be the reason two black boxes work better in Al’s room. Plus I already have a lot of treatment.
I have an ASC subtrap in my room now which I used with a sub I sold off some years back. It still helps with standing wave issues around the 70 hertz region. When I removed it once… I immediately put it back. I’m just wondering if the black box would add anything to the mix.
You won’t know unless you try. I have a bunch of diffusers in my room, but only two base traps. I built four traps, in the ASC style, but they were only minimally effective, and, honestly, the remaining two I am on the fence whether I will keep them in place. The Black Box also helps mid and high frequencies. A bass absorber, tuned to capture a frequency range, doesn’t, I don’t think.
I am also intrigued with this solution. https://www.psiaudio.swiss/avaa-c214-active-bass-trap/
I also have ACS subtraps to compliment the tube traps. I think all of them will be for sale once I am permanently at my new home with the large room. If I need any bass treatments they will be white versions of the black box and/or the PSI active solution above.
Wine if fine but whisky is quicker!
Anyone have a preferred SR dealer? I’ve always had good experiences with VH Audio for the fuses, but he keeps a really limited product selection. Tried someone else for a second tranquility pod, but got put off a couple times and ultimately ghosted.
I usually go to The Cable Company for my purchases. You can get a percentive discount on many items, bigger percentive depending on price on their frequent flyer program even if it’s your first time purchasing. No sales tax and free delivery to boot. I saved $660 on my last phono cable purchase. Check them out.
I have a SR Dealer who I really like working with. PM me for contact info. You will be glad you did.
