I have issue with Stellar GainCell DAC.
When using any digital input, sound it moved to left channel so I need to set BALANCE +10 RIGHT.
Using analog inputs, BALANCE=0 is correct.
Does it make sense? Is this software or hardware issue?
(I wish to fix on my own as the gear is second owned and probably lack of service in Poland, Europe…)
Sounds like perhaps there’s something wrong with the unit’s DAC. What are you feeding into the digital inputs? Different sources that you know are good?
