Stellar Gold
I will soon be getting a new Dac to replace my SGCD with. am I best getting another Matrix SPDIF to take the USB and convert it to i2S, or just use the USB?
What are you planning to get to replace the Stellar Gold DAC?
If it’s going to be the PMG 512 then
No need to add another link in the chain. Use the USB with a good cable. Done
Maybe I should be more clear
 I have a Stellar Gain Cell Dac at the moment and replacing it with the Gold
This helps a great deal. :slight_smile:
Ah. I don’t have any experience with that DAC. I would think you’d have to listen and see what you think. My approach is; if I experience a repeatable noticeable difference , I like, it’s worth the change.
I replaced my gain cell dac with the Stellar gold dac. The improvement was not small. At a later time I added the Airlens. I run Roon and use the I2s connection. This worked out well for my living room system. I connected my Flat screen tv to the DAC with toslink. I think I’m set for a while.
I reckon I have had my Gain Cell for about 5 years now, so going for a change. I like the “house sound” of it, was thinking of going for the Gustard X30, but there are only couple of UK dealers, and read all the reviews of the PS unit and it comes out better, so waiting for the demo unit to get to my UK dealers, home trial it,but will prob buy one anyway
I should have added that the DAC is connected with balanced cables to my Stellar s300 amp feeding a pair of Reference 3a grand veenas. -No preamp in the chain. Subwoofer is a maybe.
well I had the Stellar Gold Dac on home trial, it was very good and a step up to my SGCD. The decision is now, do I go for that or a MK 2 Direct Stream, decisions, decisions
Good Day,
With respect, Sorry to interrupt,
but Stellar Gold as a preamp in it?
Passive or Active?
And of course, how do you find the sound in the Stellar?
and what the gold will ad to that?
thanks for helping
PS planning to replace in the futur my R2R, when I scratch to many LP shaking and have to discard it.
Good Day,
With the help of this forum, just added to, my S300, very affordable sub, for trying with the REL Video and sneakers CD, song number 3. I would not go back listening music without sub. The sub play the room and with live show huge upgrade in sound and space.
For now it is amazing, but when I will find my system boring again, will promote Sub and DAC
I compared the SGD to the MK2, I kept the SGD, I found it more detailed and sharper imaging, if you like a more analog sound the MK2 might be better, maybe?
