StellarGold Preamplifier - You're Gonna Love This One!
Yes definitely. I don’t doubt what you hear, it’s just difficult to understand by a pure theoretical point of view.
I think the BHK approach was one of the superior ones sonically, although my impression from forum posts was, that its operation caused some quirks for some.
These are interesting points of views.
I have a Stellar Gain Cell DAC and a Wyred4Sound mPRE as preamps. I compared them to the Schiit Freya S and the Freya S did not sound good at all in my system; it sounded metallic and dry to me. I tried passive and the 2 other gain settings.
I want to compare the Gold Stellar to the Stellar Gain Cell DAC.
Cheers!
I’m in the SG beta both for the DAC and the Pre and previously had the SGCD, all fed into M1200s. The SG DAC and SGCD are very different creatures. The SGCD is a good start into a higher end system, while the SG DAC and Pre take you well along that journey.
However much I enjoyed the SGCD (fed by a Sonore Ultrarendu) the SG DAC (fed by an Airlens) is better by far. More open, greater presence, tighter bottom end and lovely, solid mids and airy top end. It draws me into the music much more than the SGCD ever did and on the right recordings I feel like I am in the room. Well worth checking out!
Bob
In a not so hypothetical question, if you could only keep one to pair with the GCD serving as DAC or pre, which would you keep, the SG pre or the SG DAC?
The DAC, for sure. It is much better than the DAC in the SGCD.
My primary reason for wanting to get the unit was so that I could add my turntable to my rig
Does that mean the preamp has a phono section? Or did you already have a phono preamp and nothing to play it through?
I had similar experience. ARC LS28 SE which sits between the 5 and 6 ref someplace. The difference was large.
Yes to the latter. I have the Stellar Phono, also designed by Darren Myers, and was eager to get it connected. My vintage Yamaha PX2 table is nearly ready as well.
I am not much of a YouTuber so I have not watched this yet (but likely of interest to many here):
