Can anyone suggest any improvements to use for example is there a device to Improve prove noise on the Ethernet cables. I mainly stream tidal MQA
Fiber Media Converters = Galvanic Isolation
Galvanic isolation and Cat 7 or 8 cables for added noise rejection
@perrynewtelsurf-com I’ve had customers use ferrite cores in the past with various connections. Maybe give these a shot: https://tinyurl.com/y4d74u3s
Let us know how it goes!
Thanks -
TJ
GigaFOILv4. Solution depends partly on your budget. I, and many others own this device and can attest to its influence. Plus, there was a review done comparing the GigaFOIL device to the TP-Link computer network designed product to help in your decision.
Thanks will give them a go
Does the gigafoil go where internet comes in or between cat 7 and DSD ?
The GigaFOIL is best placed right in front of the DS DAC. So, router to GigaFOIL, then GigaFOIL to DS DAC.
Mario, how do I use them. Do I put one in the rj45 connection to my DSD or do I need more than that. My router is upstairs and I use home plugs to connect to DSD downstairs
Powerline Adapter ("home plug) > GigaFOILv4 > DS DAC
