THD Reduction Performance
I have a PPP. It seems to cut-out two-thirds of THD. Right now, input THD is 1.5%, output 0.5%. Is this normal? What kind of reduction do you get?
Thanks for your contributions
Simon
Hi Simon,
This seems good. On P10 I usually get between 0.1-0.3 THD depending on what incoming in. If it is between 3.3-4.4 it is between 0.2 and 0.3. If it between 2.2-3.2 it is usually 0.1.
