I have a couple of USB-related questions:
Is the USB port on the DirectStream USB 2.0 or USB 3.0?
Is the PSAudio Windows USB driver we used for the PWD required for the DirectStream?
mikedc said Is the USB port on the DirectStream USB 2.0 or USB 3.0?Is the PSAudio Windows USB driver we used for the PWD required for the DirectStream?
http://www.psaudio.com/wp-content/uploads/2014/02/PSAudio-USBAudio2.0DriverLatest.zip
Supports the PWD, the DS and the Nuwave Phono Converter. It’s version 1.61.0.0 (you can check in the device control panel, select the PS Audio Perfectwave DSD and check the driver properties.)
Am I correct in assuming that, when connecting the DS to a PC and an amplifier, one has to choose between either a long USB cable/short interconnects or a short USB cable/long interconnects, the short USB cable combination would be the better choice?
wim said Am I correct in assuming that, when connecting the DS to a PC and an amplifier, one has to choose between either a long USB cable/short interconnects or a short USB cable/long interconnects, the short USB cable combination would be the better choice?I use a long active USB cable as an "USB extension cord" (it has to be active to be longer and work reliably) With balanced interconnects the distance isn't as big of a deal but the USB signal is digital and if handled properly it should be less affected by distance (tho there is more ground and power noise the longer the cable)
Some prefer to use USB cables that (in some cases) are more expensive. If so there are cost tradeoffs between the USB cabling and the interconnects.
