I use a NuPrime CDT-8 Pro, with its sample rate converter set to DoP128.
Do you also use a standalone DAC? If so, what is it?
Thx for helping,
Chaz
I use the DAC in my Stellar Gain Cell DAC/Preamp. NuPrime said their HDMI cable pin assignments at their I2S output matched the SGCD’s I2S input, and they appear to be right. It works great.
That is superb-to-know data! Thank you.
Jay’s Audio Transports work wonderful with I2S to the DSD.
It works swell with other methods to other DACs as well.
I am using the pink faun I2S soundcard. Works like a charm. Technically I guess I could spin discs from a drive in a PC using this card, but I am either streaming or playing rips.
