After reading many threads & posts here, I recently added two new 20 amp circuits to my listening room/home theater, including one circuit dedicated to my PS Audio PowerPlant 20. Previously I had one 15 amp circuit powering all of my equipment and room lights, router, etc.
WoW what an improvement in sound quality!
The easily heard improvements include: faster, wider, & deeper dynamics, smoother mids & highs, wider sound stage, blacker backgrounds, and an overall cleaner sound! I was finally able to upgrade my PS Audio PowerPlant P20 power cord from 15 amp to 20 amp (C19) to use the P20’s full capabilities.
The sound improvement that I already hear from this upgrade (without the breaking in of wiring/cables) is, in my opinion, better than spending $10000s on new equipment upgrades. I think that upgrades to electrical service for audiophiles & videophiles should be recommended more often than they appear to be and should be made before other much more costly equipment upgrades. I think it is akin to fixing the base of a system pyramid with all other equipment improvements layered on top but being dependent on a good base layer of clean electricity and copious electricity & power. Fixing the pyramid base of a system helps all of the other layers above perform better!
Thank you to the many PS Audio forum members who have previously posted for providing advice on specifications for an electrician to complete this job! Of course my electrician said that nobody had ever requested 10 gauge wire with no splice circuits before, but pulling these thick 10 gauge wires through metal conduit only turned out to take about 30 minutes with 2 people (my completed installation took many hours in total).
My 2 new 20 amp circuits had these specifications:
-Wire: Romex 10/2, solid core, each circuit wire run continuously as “home runs” from panel to receptacle with no splicing.
-Conduit: metal (about 1.5" diameter), surface mounted on outside of house containing wires for both circuits.
-Breakers: 2 new 20 amp breakers wired to bottom of electric panel where incoming electricity comes into panel
-Circuits: both wired to same phase in electric panel
-Receptacles: 2 PS Audio PowerPorts using the isolated grounds wired directly to each receptacle
-Electrical outlet box in wall: 2 gang, metal, containing both receptacles, side-by-side
-PowerPlant 20 amp power cord: new 5 foot Iconoclast BAV 10 gauge power cord with C19 connector. P20 is now plugged into its own new 20 amp circuit
-Existing 2 subwoofers: plugged into 2nd 20 amp circuit (not through P20 as they were previously)
-Existing 15 amp circuit now has router & other noisier type equipment plugged into it
My electrician also installed/buried 2 new ground rods since my existing house ground was only to the cold water pipe. I was told that this brought my home’s grounding up to current electrical code. Unfortunately, I was unable to get before and after resistance to ground readings from the electrician as they did not have the proper meter or probes.
Special thanks to @BobBJC at Iconoclast/Blue Jeans Cable for expediting the new power cable to me! ![]()
Thanks again everyone for your earlier forum posts, suggestions, and advice!
Carl
