352/24 bit FLAC files
I see that HDTracks has a new type of files 352/24 bit files.
I was wondering if PS audio can play these files?
Thanks
Henry
The DirectStream will play them over USB. That rate is too high for TOSLink, S/PDIF and AES/EBU.
Does it play over Bridge?
IIRC, the Bridge is limited to 192kHz/24.
That’s correct.
henry1224 said I see that HDTracks has a new type of files 352/24 bit files.
Thanks
Henry
I’ve done some tinkering with contverting dsd to wav with jriver because when i tried to convert to mp3 directly it was failing (I had to convert some of my library so it would be compatible with Amazon/Itunes for my Son) my point is 64 and 128 dsd where crazy high bitrates before i brought them down with another conversion.
