Can you add Primephonic to your direct connections through Bridge II? Best classical interface by far and they will stream high quality audio. I’ve been streaming via Bluetooth through another device (blue node 2i) and the sound leaves a lot to be desired.
Add Primephonic to DAC Bridge II?
Not unless Conversdigital adds it to it’s list of supported services. Same with Amazon HD. You will have to connect directly from the Node 2i or other device by either USB, Coax or optical.
Streaming is the future. PSAudio needs to hire someone to build their own app that gives access to a variety of streaming services
They are along with an in-house streamer, they are called Octave due out next year. From looking at their website I can’t tell if Primephonic has released their API to anyone as they don’t list any partners.
