Are dedicated lines enough?
Hey, I’m using an M-1 in my P20! But my thinking is as follows. I heard for myself today that with better (if not ideal for my Pass amps) cables I get my system sounding better than what I thought was already d@mn good - that is, with unknown quality extension cords plus the Pass stock cords into my P20. Next, I really am not fond of bringing back into my system another active device (P15), cluttering my sound room (especially on the speaker side of the room!), itself requiring “optimizing” (better fuse, better power cord for it). After almost 50 years at this game, I know when good enough is good enough for a given experiment (I’m trivializing what is by far the best system I’ve owned, and one if the best I’ve heard anywhere). I don’t need to make my system more complicated at this point in my life for what is likely to be only a marginal improvement. When I consider additionally the P15 will bring me that much closer to the DS MkII (trade in, you know!) - what is certainly to be a far more significant advance, then for me just getting better cords will suit my goals. Unlike Al, good man that he is :wink:, I need to sometimes make trade offs.
The best audiophile I know are the ones who know when to stop, and I wish I am in that group one day. I spend as much on cables and cords as on my components, and I wonder if that makes any sense often!
Enjoy your journey in this crazy audiophile world!
Thanks. It only took me about 35 years to figure this out! :crazy_face:
[quote=“tony22, post:38, topic:30779”]
Hey, at this point all I’d like to find is a good 5 cent cigar! I mean, sub $1000 cable for my amps
$999.99
My brother uses them. Have heard them a few times over the years (he lives in a distant state) never did comparisons but his system sounds nice with them in it
Hmm, now this is one I hadn’t seen yet. I’ll give them a look. Thanks!
One of my favorite sources for “budget” cables.
Specs are an emphasis and quality and service are top notch.
Call and talk to the proprietor, Frank, if you have any questions:
http://signalcable.com/power_cables.html
Tony
If you don’t want to go broke buying cables to find the marginal gains we’re all after, consider this:
When you first heard your Pass amps, were they powered by his stock cables? Mine were.
And that listening session sounded wonderful enough to make you buy the amps. In my case, I was floored by the sound of the amps with the supplied cables.
So what changed? They still sound that good with his cables.
And—in my case-- I found that all of the Pass amps that I’ve owned were unresponsive to changes in cables until I got to very expensive ones. The cables that I use do make a noticeable improvement but they’re roughly $5k each.
For the marginal gain, I’d rather spend $200 on a fuse than $1,000 each on cables. They’re both “a pig in a poke”.
Just a thought.
Thanks Scott. I’ve used Signal Cables in the past. Nice budget cables.
A smart, reasoned bit of logic, Ron. Yes, they did sound great - and still do. In my defense, though :smile:, over time as my surrounding system has gotten better and better, the small weaknesses become more noticeable. Now that I’ve heard the improvement that’s possible, as a result of changing the amp cord, I’m going to always know it’s possible if I drop back to the stock cord. Could I just leave the Shunyatas in place? No. For what they do in reduction in grain and improvement in blackness, they shift the tonal balance some in a way that I know “isn’t right” - for me at least. But your reasoning is sound. Maybe I should replace the fuses first. Cheap enough. Do you have any recommendations here since you also use Pass?
As to the cords, yeah I’ve read your post here over the many years trying power cords on your amps. Sigh. Now I’m talking against the stock cords here! Did you not find a lower cost ‘break point” cord along the way where you could say “that would be a decent landing spot”? :pray:
I like the Shunyata Delta V2 for an inexpensive 'all around" cable. They are 10ga. They power my second system including the 2.3 watt tube amp.
But they did nothing imo for the Pass amps.
Once again, sigh. But I appreciate the response.
I get good performance - que all the standard disclaimers, my system, etc. - from VooDoo cables Integrity (digital) series on my DAC and CD transport
I think they are around $500 after frequent flyer discount at the Cable Co.
Best,
-JP
Link
Power CablesCables (thecableco.com)
Thanks John. The Cable Company and I are old friends. :slightly_smiling_face: Used them on and off over many years. I wish they did more than two weeks for trials, though. I found that not to be enough time (for me) if comparing more than a couple of cables.
We run all these 20 amp dedicated circuits with 10/2 wiring, and I know it makes a difference, but I wish the utility companies had to run the proper size wire for the service drop, they don’t even figure allowances for voltage drop, just temperature. Ever notice that the aluminum alloy wire from the pole to the mast is lower guage than the copper wire you have to have in your service mast.
My inner nerd came out last week and I calculated the weighted average (weighted by price) age of my audio system. It came out at 4 years, and would have been about 5.5 years if I hadn’t bought expensive new speakers in December 2020 for cosmetic reasons and to save my marriage.
My only cable indulgence was for Shunyata as per @tony22, they seem to reduce noise even if plugged straight into the wall. Shunyata Delta, I don’t know what version.
I finally gave in on my 10 year old $5 Chord-C usb cable and bought a $250 silver job from Artisan Cables, mainly because it is a lot shorter (0.6m against 1.5m). That is not an indulgence given people here spend more on fuses. It was probably a waste of $250.
Interesting. I tend to keep things for a long, long time. So maybe that means I should allow myself to raise the spending limit for cords on my amps. After all, over the long term the cost per year will be reasonable. :grinning:
Most of my cheaper cords end up in a pile I need to sell, as going back to them never scratches the itch as I just found out with power cords and ICs. Even the magic wraps and tweaking tricks don’t seem to resolve but do improve. Having second systems offer utility and back up but why turn them on when better is available and functional in another room. Listening for background noise I prefer silence to second rate.
I had probably 10 years plus on my old system until I ran into the PSA sales. Once I joined this forum the flood gate opened and I could not stop buying.
Looking forward to the MK2 review!
My experience on cables lately seems to point to the better cables cost more. One exception is the Zavfino Silver Dart power cord, it was so good that I still use them to power M1200 amps. They replaced a pair of AQ Thunders that is saying something. Their price has increased from last year so Silver Dart may be over $1k now.
