I know “why” it sounds different, not the HOW. The EM wave is CHANGED.
We hear the initial PHASE of the signals, alignment at the start of the cable. We then hear the superimposed group delay, or how the frequencies CHANGE phase as they travel down the cable cause by the Vp differential caused by frequency differences.
Two cars are lines up at the start line the same way. But as they travel down the road, one goes faster than the other as it is allowed to go faster (higher frequency). Thus, the arrival time is changed. This is worse if they aren’t initially lined up in proper phase. Now we add-in the wire’s contributions.
Somehow, the copper structure must alters the amount of each time delay that we hear. Our ears are very time sensitive more than frequency response. I know how to change phase (inductance) and Vp differential (capacitance and resistance). So we kind of have tools to manipulate that.
I can measure Vp differential in wire, and use equations to roughly duplicate the measurements transfer function. And, lower inductance lowers phase. I can’t point to a given wire’s structure of attributes and say, “this one attribute is what we are hearing because it does THIS”.
I have ZIP tools that define how to “adjust” what wire structure does except to offer them as alternatives…so that’s what we do.
ICONOCLAST, all of them; speaker and IC’s are designed to mitigate TIME errors through measurements and listening test to confirm that the improvements are worth the effort to achieve. The use of smaller wires is necessary for managing Vp differential (not so much phase), and I’m not the only designer that knows this. HOW you do it is, of course, creating different sounding cables, copper being the same.
Best,
Galen Gareis
I don’t personally see “bright” as bad, and certainly neither linguistic nor audio criticism was implied. I just generally try not to use it when what I am perceiving is openness, clarity, detail, and air, as Elk clarified.
. No criticism taken. I just find it fascinating. I heard what others heard in the SPTPC, but every time I went back to the TPC, it was like the timing “focus” was better. Yeah - I was potentially “giving up” the things the SP added, and I didn’t think they were sonically offensive from a “brightness” perspective.
Galen
