I recently fully powered down my 600s for the first time in a few weeks and then powered them back on about a half hour later. I normally leave them in standby mode when not using them. Coincidentally or not, my system then sounded more alive and brighter than recently. I power the 600s with a P20 so I doubt it’s because of power inconsistency issues. Is there something to this or am I just crazy?
If you are crazy, then I am too - this happens to me every time I travel. I even had a hard-to-track down hum (ended up being damaged shielding in turntable interconnect) that would mysteriously disappear after turning the system off for a while (??!??)
I am completely powered down and will see if I can tell a difference with the 600’s when I return home from vacation.
This might be an inaccurate test as all the units are unpowered. I have never noticed a change in the past. I do think a 30 minute warmup helps the amps. Probably the tubes.
On the other side, I have noticed on occasion a sonic bump with digital components. I attribute this to a good old fashion reboot.
This has been discussed many times. And although there has never, in my opinion, been a convincing technical explanation as to why, it seems that shutting your system or component down and restarting after some time may be sonically beneficial.
When the system stays on for an extended period, the dark matter and heat will be trapped inside components. The sound will turn darker. A total shutdown will allow these elements to escape, and the system will sound better.
No one could prove my theory to be wrong (or correct) so far.
Oh, I thought letting the smoke out was the best way to “cleanse” the system. ![]()
In our listening room we power cycle our 600’s about once a week. Usually it’s from changing out equipment in the stack. It never hurts to give them a rest every now and then!
