BHK Preamp rear Fuse Holder - trying to source replacement part (UK based)
I sold my BHK Pre and the buyer has let me know the fuse holder broke in transit, how, no idea!
Is it the standard Shurter fuse holder, looks like it might be?
Or is it a particular specific part used on the BHK Pre?
Want to post it out to the guy so he can repair it, just wanted to double check which one to buy. Thanks.
do you have any other PS audio equipment, if so you could pull out the fuse holder and compare it to what you find on the web. That’s the only way I can think of doing it un less PS Audio can tell you a source to obtain a replacement from.
Best of luck,
-Tom
Of all the things that could break in transit, this wouldn’t be on my list.
Did you change out the fuse before shipping?
No, hadn’t actually used the amp for a few months.
Thinking it’s one of these?
I’d ask @jamesh. If anyone can find out, it’s him.
Yeah, that looks right. Let me double check it’s the right size. I’ll have an update tomorrow.
This is not the exact one but it’s close. We’re using a board mounted holder. Part number is Schurter 3101.0050. Good luck!
James,
Thanks so much for this!
Atb Gaz
Today’s lesson: Never underestimate the tenacity and fantastic customer service of @jamesh. He’s a beast!
Oh 100%
Customer Service 2nd to none
