BHK preamp tube rolling problem
Hello
I try to roll my BHK preamp tube but when I open the top shelf , seem I cannot locate the tube inside but just the large toroida transformer as show in the picture
Did I do anything wrong ?
Rhank
Hi, it look like your top cover is 180 degrees turned. The ‘open part’ should be close to the backside, not the front. Best regards, Jos
Thank … in that case need PS audio advice … how to remove the entire upper ‘black cover’ ?
Does that mean my unit has issue with the wrong orientation of the upper lit ?
Thank
Thank … I checked with another thread about how to open the top shelf and did it. I also reverse back the orientation
Thank for all the help
