BHK Preamp tube rolling
would it be 6922 to 6sn7?
9 pin on bottom
These tubes have woken the beast in my system- grow some smokestacks out of your BHK!
thanks. I actually answered my own question after I had typed that out. Here’s another, does the 9 pin saver have the same height, or serve the same purpose as the extender. Looks like tube depot has them
Socket saver yes
Forgive the cable mess- moving stuff around :slight_smile: as usual- my audio room looks like Frankenstein’s lab right now
looks great!
I made a cover for mine
DSCN0034
What did you use? Don’t have the tools if it is steel
It was a piece of steel mesh I bought from Lowes, used a grinder to cut to size and the two holes for the tubes, then painted with black spray paint.
Gotcha
Those Little joker 6an7 to 6922 converters are bi*ch to find in Canada.
Did you try Parts Connexion?
Yeah… looks like they have the 9 pin extenders, but don’t carry converters
Might be worth a call as sometimes not everything Chris has in stock is on the website.
Check ebay
Ebay’s from China. May just grab em from the tube depot
What’s wrong with China sourced products. May be slow, but I just got something
In 10 days. They are $15 each on EBay.
I have received tubes from China in less than a week - in a cute homemade cardboard box.
Represent!, so far my favorite tube
