My 5-yo BHK signature preamp has developed a low (but noticeable) buzz on the right channel only when the preamp’s volume is between 40 and 56. These nodes are also points where an internal relay clicks, I assume to activate/deactivate a specific part of the circuitry in this range of gain. Anyway, volume below 40 or above 56 are devoid of the right channel buzz. (FYI: I now routinely keep my preamp at 57 or higher and adjust volume via the gain control on my PS Audio DirectStream DAC.) I’ve contacted PS Audio support and they believe, as do I, that there is fault in the circuitry that requires their service. I’m currently working out the details for this.
I’m writing out of curiosity to ask if other BHK owners have experienced similar volume-range, channel-specific buzzing? There is no insinuation about PS Audio quality; I like their equipment and plan to continue to include their components in my audio system. As I said, this is simply provoked by curiosity if my situation is a one-off.
Best,
Bob
