Bit Perfect Test via I2S input
HI all,
Just wanted to find out if Bit Perfect Test work if my streamer is connected to DSJ I2S input. When playing the test file it doesn’t show on screen that it is bit perfect so I’m wondering is it something in my chain before it reaches the DAC or the input cannot be used for this test.
Thanks in advance,
Gints
The DAC will detect the bitperfect test pattern on any input including I2S. Something in your chain is modifying the data.
Thanks a lot for the answer, will investigate.
