CD cabinet recommendations
What would you recommend for cabinet or shelving systems to store CDs?
Aesthetically pleasing. Simple clean lines.
http://www.can-am.ca/CD-storage-DVD-storage.htm
I looked at these. They are too deep for my space. Looking at something shallower 6”~8” depth.
Wonder if they sell the upper unit separately.
They do. I just sent you the link to what I have.
They look very well built. I like the modular aspect.
If all else fails, build your own. I was quite pleased with the results.
Elfa is great. Customizable. Available at Container Store.
You did a very nice job with those. I cut my self short and picked up some from BestBuy. Rather flimsy to say the least. They get the job done, but if I had to do it all over I’d either go custom or maybe CanAm.
CD Storage
Thanks. I did all the case work in the basement including the equipment racks. Before I listened to mom and got a couple degrees I completed the program to become a journeyman carpenter. I’m really glad I no longer do it for a living but I’m real happy to have that knowledge went I need it for myself.
An inexpensive solution is IKEA Billy bookcases. Looks reasonably ok (nothing fancy), but works well.
+1 for IKEA. I have their towers that house 180 CDs each. Awesome.
Fan of Billy here - good for modifying as well - I have home network cabinet in one, with cut-outs for fans in the sides and cables in the back - works a treat and quiets any noisy gear quite well too :slight_smile:
It appears that those towers are no longer for sale. Can’t find them on the Ikea US site.
Yep, discontinued ages ago. Maybe Ikea will come to their senses
damn i was planning on buying another one :frowning:
Not the Billy, but the Gnegby.
Yes. That’s the tall thin one for cds.
