System turned on after nearly a month (was totally powered off from the main power switch at the back of P20), sound in left channel is significantly lower. All components and cables checked and problem seems to be in the power amp feeding the left channel. Any idea what’s going on people? Has anyone had this issue?
I don’t own BHK gear. Do you have access to a tube tester? You might try switching the tubes between channels or try another set of tubes. Verify the balance is set correctly on the preamp.
Tubes. I know you said it was turned off for month so in principle if the tubes were ok before they should be ok after. Be that as it may, I’d be switching tubes first act to diagnose the problem. That’s assuming of course you’ve checked your balance controls as James suggested.
Perfect, testing. Can’t ask for a whole lot better. In order to make the image sound in the center, how far do you have to adjust the balance in the pre to the left?
One more suggestion. Try power cycling everything even though the system had been off awhile. No joy? Let your fingers do the dialing to PSA customer service. They’re the best.
