Connecting 2 JTR RS1 subs to SG DAC
I have two JTR RS1 Captivator subs, and I currently have them connected to my Denon X4400H AVR using the XLR inputs on the subs. I understand that I can use the RCA outs on the Stellar Gold DAC to connect to the RCA inputs on the subs too. The subs have L and R RCAs, with the L RCA input also labeled as LFE. My question is how do I connect my subs using the RCA outs on the Stellar Gold DAC to each of the two subs? Should splitters be used from the Stellar Gold DAC RCA outs so I can plug into both RCA inputs on each sub? Thanks for the help!!
With two subs, run a separate rca from the L and R of the amp to the R of each sub, placing them tnem more or less on the two sides of the listening space. See Paul’s latest response on YouTube covering subs. As each of you subs has one speaker, its electronics are combining L and R to make a mono input so the sub is producing bass from both channels. With two subs, you can set each to play one channel.
Thanks for the tip! I’ll look at Paul’s video too. When you say “amp” do you mean the Stellar Gold DAC? Thanks
Sorry, read your post too quickly. DAC rca output fine.
Thanks again!
