Different filter setting? I'm not getting it
What are the sound changes that I should be hearing with the difference filter settings in the SG DAC?
I’ve flipped through them and don’t notice what’s difference.
I have an Astell&Kern music player that has that ability also, and I don’t hear it there either.
If the SG is an ESS based DAC then you will be hard pressed to hear any difference in the filter settings.
It’s a blessing not a curse. Worry about something else.
Not really “worried”. If they build this feature into a DAC, it should be something I can hear. Does one smooth out the higs, soften or sharpen the sound, etc…
Just thought someone could point out the audible effects of these filters.
This topic has come up before. You might want to give this thread a look. https://forum.psaudio.com/t/stellargold-dac-filters-anyone-figured-them-out/38042
