Directstream DAC 110Volt --> 220 Volt
Hi there,
If I wonder if a local directstream DAC (110 volt) can be used worldwide with 220 volt?
Do I have to send the unit back to PSaudio to modify it? I do hope the DAC automatically voltage-select.
Thank you
It can only run at the voltage it was set for so no, a 120 DAC from us will not do well at 230 and it can easily be damaged. If you need it converted you can contact your local distributor in the country you’ve moved to. If you bought it in the States and imported
it into another country they will not change the voltage for you.
