DirectStream DAC MKII changing the single power transformer
The DirectStream DAC MKII is fitted with a single multi-winding toroidal transformer around 50 va.
Like to ask if anyone has replaced it with 2 or more transformers to supply the digital and analogue pcbs separately. It appears each pcb are supplied with 2 rails of 16 vac.
If so, is there a chance you may be able to share your work.
