Directstream Regulator question
For me it was the midrange. Vocals in particular.
That said, I think every aspect was better. I personally noticed mid had the most positive effect.
Aha,okay,i will be aware of that and observe the sound…now it’s twoo days…more to come…Ted sad,that burn-in is high hundreds of hours,so,that may not be correct,as twoo weeks are 336 hours…Edcor also says,that these hours aren’t proper,it is less,than that…But,if you have this experience,i can believe you…so,little waiting needed…
:joy: that did make me laugh, thanks Elk
I felt the biggest effect (for me) was in the bass, but these days I can’t even remember what I had for dinner the night before (unless it was an expensive night out).
So,in whole matter,it is the midrange and bass,so,mostly the whole spectrum,which is better generally…how much did you burn-in DSD DAC,you have also upgraded transformers?
May i ask forum guys with upgraded DSD DAC’s,on which volume level are you listening,if the DAC is feed directly to amplifier? I have level of 50 in my room…
When I ran my stock DS direct to my JC5 amp…I varied the
DS’s volume control to adjust volume to suite my taste at that
particular moment…
Going DS direct to amp it will be necessary to utilize the
DS volume control as you would in preamp…
As an aside…while I really was impressed with DS direct to
amp…there was much better sound quality, spacial retrieval
and body to the music…my premp is a Stage 2 Wyred4Sound
STP SE…
My .02 thinking is that the same would hold true for a moded DS…
Hope this helps
Best wishes
You did not say,at which level volume is set,when directly to the amplifier…Is it 50,or 60?
You are right…because you will need to vary your DS’s
volume level to meet the your individual needs…
Too soft …then raise volume… too high…then lower volume…
use your ears…they will tell you what is best
Best wishes
When it is 60,you cannot listen?
Does your power amps have adjustable gain levels?
Or are they fixed?
I have Cello Duet 350 amplifier…I don’t know,probably it is fixed,no regulation to be seen on it…
Nice amp…it seems then that amps inputs are fixed…
Your sound level comfort will tell you the proper
DS volume level…simply adjust to your taste…
Let your ears be your guide…
There is no right or wrong level when using the DS as
preamplifier direct to amp…
Don’t get hung up on a numbers game…
Running my DS to preamp I set the DS to 97 and vary my
pre’s volume to suit my desired listening level.
If you ran your DS at 97 direct to amp…you would either blow your speakers or your ears or both…
I would start low on the DS direct to amp and raise the DS
volume control until you achieve your desire listening level.
Best wishes
Thank you…
There’s a LOT of variability on that since the gain on every amplifier is a little different - 50 on an amp with low gain will be too soft, but on a high gain amp will blow the listener’s ears off. Some even have to initiate the attenuator.
The DS does have lower than ā€œnormalā€ max output voltages though - 2.818v on balanced and 1.414v on unbalanced, so even maxed out, the final output (if not using a preamp) will be lower than a source that has the ā€œtypicalā€ output of 4v balanced / 2v unbalanced. Even with a preamp, you would likely find the need to set the volume higher than you would otherwise with other source equipment.
Edit: I should mention that I don’t believe the better Edcor changes anything as far as output voltage, as they are both 1:1 transformers (I think).
I cannot set volume louder,than 60…how much you do set it for,if on amplifier directly?
I have personally never tried DS direct to amp, as when I got the DS, I already had a preamp, and have PERSONALLY found in the past that a preamp consistently improves the overall sound. I used to use a Wyred STP-SE, but recently got my hands on a BHK.
If you prefer to use the DS direct, but would prefer to set the output higher, have you tried initiating the attenuator?
There’s a quite long thread in the DAC forum with a lengthy discussion about volume settings between members, with some saying they can’t even go over 40 or 50 when using the DS direct, and I recall some even complaining that they can’t get it loud enough going direct (ie. where the low DS output voltage, variability in amp gain, speaker efficiency, etc. come in to play).
I wouldn’t get stuck on any specific volume setting at all, since the volume in the DS is technically lossless because of how it works. Whatever setting works within the parameters of your system (amp gain/speaker efficiency/room interaction) is what works in your instance.
On the other end though, there seems to be consensus, including Ted’s input, that the DS sounds best at about 93-95 MAX (not min) because of the software/firmware for the FPGA, signal/noise, etc. when using with a preamp.
If you search ā€œvolumeā€ in the DAC category, you’ll find quite a few discussions about it. I don’t recall which thread specifically addressed the 93-95 max thing, but I recall it coming up in more than a few threads.
Great answer tak1313…
Wonder how my Stage 2 would compare with BHK pre…
Needed to say my Stage 2 is amazing !!
Best wishes
It is better with preamplifier then…50 is enough volume for directly to amplifier…more you cannot set,only,if cd is recorded silently…
Before I got the deal on the BHK, I was debating about the upgrade (Stage 2, since the Stage 1 seemed kind of useless in light of the Stage 2 and the cost difference). I really don’t know how the stock versus upgraded would be.
I’m debating about getting the upgrade anyway, then comparing it to the BHK. Have you heard it stock before upgrade, or did you buy it with the upgrades installed (since Wyred sells them both ways). If you did get it stock first, what’s the difference?
Where do you live? If you live around New England, you can try my BHK in your system to see (I live in NH). It currently has Gold Lions.
