I just ordered a DMP and since all my other equipment including a Direct Stream Dac uses the Synergistic Blue fuses, I would like to get one for the DMP.
Can someone share the tube value and size?
Thanks,
Ken
Thanks,
Ken
Hi Ken. I checked the fuse in my DMP and on the fuse is written…
T1.6 AH 250V
Hope this helps…
Mark thanks for that info.
But is the fuse the small size or the larger size?
Ken
Small…
Thank you so much!
Happy New Year!
Ken
Your welcome Ken!
