worth installing in your view?
On paper, thinking ferrite cores on the power rails might be enough?
After installing all OPPOMOD itens and the AC filter, the ferrite filters didn’t make any difference. So, I left them there.
Were you able to buy the breaker version of the LPS SE without sending your unit in? Or you just modded it more once it came back?
What is the max DSD sample rate the oppomod’d 203 and Directstream combination can handle? I saw on a board somewhere that their 203 could only handle a max rate of 128.
Thanks,
RJ
I didn’t want to start a new thread on this but I’m curious if anyone has been able to compare the I2S modded 103/203 back to back against the DMP and the DS Sr Mk1? I have the 103D/Sr Mk1 using the RAL and the SQ improvements over digital coax is quite impressive. I want to assume the DMP has some added goodness to it but would like to hear opinions. The only thing I have done to the 103 is the I2S card, no LPS yet.
I have a fully modded Oppo 203 with the I2S card. I used it with the DSD Mk1. Vs. the PST the oppo was close with both SACD and standard CD but I would give the nod to the PST.
I also have a 203 with the Oppomod board. Mine does a weird thing, when I adjust the volume on my preamp (using the Oppo as a source to my DAC) I get clicks and pops. Strange. I wonder if its a “pin out” issue with my i2s
