DSD Direct
Hi,
I’m sending a Pure DSD signal from my HIFI Rose 150B steamer to the PS Audio Direct Stream DAC using the USB interface. Receiving the signal it is apparently a DOP signal. I have checked the signal sent and it is a Pure DSD signal. On the DAC screen it clearly states it is a DOP signal. How do I get this right?
I tested what happened when I send a DSD signal from the PS Audio DMP (SACD) but I get the same result (DOP).
Please advise on how to get a Pure DSD signal through.
It’s right, as far as I know. That is how PSA “packages” DSD for transmission to the DAC.
Search the forum for “DOP” to learn more.
Thanks
I may stand corrected.
See here:
Hopefully, others will chime in.
Good luck.
