What Makes DSD Audio (Potentially) Unique. A DSD Primer. Or DSD For Dummies.
- Super(?) High Sample Rate.
- Delta Sigma Modulation.
- 1-Bit Samples.
- Noise Shaping.
- Low Quantization Noise.
- Low Distortion.
DSD, Direct Stream Digital is a file format trademarked by Sony and Philips. The format was initially created for archiving audio signals and then commercially used for SACDs. At the time of this writing, DSD audio files are available as media downloads without needing to use the physical media.
Super High Sample Rates.
DSD 64 is called so because the sample rate or sample frequency is 64 times higher than the CD sample rate of 44.1KHz (44,100) samples per second.
64 x 44,100 = 2,822,400. Again, samples per second.
DSD 128
128 x 44,100 = 5,644,800 samples per second.
And so on.
Delta Sigma Modulation (Sigma Delta Modulation. Same. Same. Mostly).
Delta-sigma modulation, simply put, is a method for encoding signals into digital signals. It is just a different method of encoding than PCM (Pulse Code Modulation) is.
What delta-sigma modulation does differently is that it does so at a higher sample rate than PCM does, but with the higher sample rates, it only needs 1-Bit samples.
The delta-sigma modulation process uses a negative feedback loop to correct for the quantization errors that are inherent in converting an analog signal to a digital signal.
About the “errors”: Think pushing a wheelbarrow up or down a flight of stairs instead of up or down a ramp. The vertical distance between the steps (digital signal) is missing the slope (analog signal). No matter how low of a height difference there is between the steps, there will always be a ‘bump’. Bumps lead to errors which lead to noise. There is a mathematical remainder (error, noise) between the digital steps that the analog slope provided before the A to D conversion.
Delta means difference. Sigma means Sum.
1-Bit Samples.
Due to the high frequency sampling and the DSM process of quantization, with the negative feedback loop, only 1 (ish) bit is needed. Basically, the single bit indicates if the current sample voltage is higher or lower than the sample taken before it. When the bits indicating up or down are mapped out, a wave, like an analog wave, is the result. Hence the need for only 1 (ish) bit.
Noise Shaping.
The errors that are there from the conversion of an analog to a digital signal are moved up and out of the way. The noise that is the result of the errors created by quantization is still there but noise shaping places the noise in bandwidths outside of the desired frequency range, the frequency range of the original signal. When the file is accessed, a filter blocks out the noise that now resides in the higher bandwidths. The result is a higher Signal-to-noise ratio.
Essentially, Noise Shaping, sweeps the noise that comes from the quantization errors under the rug so that we do not see them. Or, as with audio files, we do not hear them.
Noise Shaping provides this. Again, the noise is still there, it is just in places that are more out of the perceivable way. So it sounds like less noise is in the playback of the file.
Low Distortion.
For audio files (and audiophiles) distortion of an audio signal is usually very unwanted. Distortion occurs when the wave of an output file does not lined up like it is directly on top of the source file. When analog signals are converted to digital signals, there will be distortion – steps vs slope.
And again, Noise Shaping and, perhaps, more so, the high sample rate are our audiophile friends so that a file can be played back with low distortion.
Putting It All Together.
All the above make for a clean natural sounding audio file. If the original analog source file is good, the converted DSD file should also be good.
Yes, as in most things, if garbage in, then garbage out. So, DSD is not a magic bullet solution for all genres of music or for specific recordings.
So, What Makes DSD Audio Files Special?
In a nutshell:
The High Sample Rates.
Noise Shaping.
Without these you cannot achieve the resulting:
- Low Distortion.
Adding What @dvorak So Eloquently Wrote To Sum It Up (To Have It All In One Place):
Further Information.
As this is not all encompassing, here are some links to further information:
A Deeper Dive (Thanks to @tedsmith and Richard Murison)
A Few Videos:
Ted explains DSD - Paul McGowan, PS Audio
PCM vs DSD - Paul McGowan, PS Audio
DSD Explained part 1 - The Hans Beekhuyzen Channel
And For Advising Or Joining In The Conversation That Started It All:
With Thanks To:
@gfuhrer
@Baldy
@terzinator
@tedsmith
@scotte1
@dvorak
@MikeK
@waymanchen11
@aangen
