I have many uncompressed WAV files (1141 kbps) and I would like to convert them to FLAC (192 kbps).
Anyone have experience with a good converter?
I am on a Windows 10 machine and I created these files recording some old cassette tapes (totally out of print and not on any streaming services) using an old program called CoolEdit 2000.
I just want to ensure getting 192kbps flac files from the uncompressed wav files.
dBpoweramp is a traditional recommendation. As an alternative, you could also use Foobar2000. There should be plenty of decent guides floating around online.
Ummm… the thing about FLAC is you can’t guarantee any particular size of the output file. Because the L stands for Lossless, there are limits to the compression you can perform.
You can adjust the amount of CPU effort your FLAC encoder applies towards getting smaller file sizes (as a trade-off against the amount of time it takes to do the encoding) but you’re not going to get 85% reduction unless your original audio is mostly silence or pure sines.
If you want good-sounding 192kbps, use AAC. It won’t be lossless though.
I am curious as to how you arrived at this 192 figure?
FLAC allows different compression levels, from none to maximum. With hard drive costs what they are I don’t need any compression. But instead of using FLAC I choose AIFF.
If you’re an old-time Windows user like me and are comfortable using command-line tools then you might like to consider the ‘official’ FLAC command-line toolset found at FLAC - What is FLAC?
Some programs like Exact Audio Copy for example actually use these FLAC tools to optionally compress after ripping.
I know the tools you are talking about and I don’t miss them at all after buying dBPoweramp. No sir. Much bother, zero gain. Spend $50 and live easy. Sometimes pennies are better spent.
Hey @aangen, I got the 192 figure based on some of the resolutions I see via Qobuz.
BUT, I have since realized that when I recorded these cassette tapes to my computer, I did so at CD resolution ( 44.1kHz/16bit), so, I am content to go with this as the resolution. I am just using a very low compression ration (8) when transferring the uncompressed WAV files to FLAC.
I love dBpoweramp! I love the metadata editing and how it can find the album covers in DISCOGS.
So far, this is working great on my Eversolo-DMP-A6.
I am also now starting to explore the wonders of DSD too. I had some test files and have those over on my DMP-A6 via a USB stick. Have yet to buy and an install an ssd drive for the DMP-A6.
What you see on Qobuz is “192kHz”, meaning that the digital file provides 192000 24-bit samples of the audio waveform every second.
That’s very different from 192kbps which means that your audio file only requires 192000 bits of storage for every second of audio. The “192” is just coincidence.
FLAC is basically “zip” for audio data. It doesn’t care whether your sample rate is 44.1kHz or 192kHz and your sample depth is 16 or 24 bits. It just lets you store and retrieve that audio data while using a bit less disk space than WAV or AIFF, plus it allows you to put metadata like title/artist/album and an image in the file too.
Sounds like you have your process worked out, which is great!
i remember the first time I saw @aangen mention his preference for AIFF over FLAC, and I quickly went and re-ripped a good CD and listened and tried my damndest to discern some kind of difference between the two.
I couldn’t and I haven’t worried my pretty little head about it one whit since.
If I want REALLY good sound I will play an SACD and I will sit in my chair convinced it sounds better but also with the calm realization that i probably couldn’t accurately pick A over B in a blind test.
If the format you rip to is lossless then you can convert to whatever format you later like best at any time. There are a lot of good tools to do the conversions from one format to another, dBpoweramp among them.
What is the difference between capitalism and communism?
Answer: Under capitalism it is dog-eat-dog, and under communism it is the reverse.
Seriously though, there are so many variables involved (e.g., FLAC compression level (0 to 8), the software used to encode FLAC, the FLAC and AIFF playback software, the file playback device’s operating system and processing power, the media on which the files are stored (e.g., spinning HDD, SSD, SD card, USB thumb drive)) that it is difficult to make sweeping generalizations about lossless format sound quality.
By contrast, it would be equally difficult to quibble with a statement such as “AIFF sounds better than FLAC to my ears when played on my system.”
We’ve had this debate a couple of times before. FLAC vs AIFF vs WAV. Most people do not hear any differences between them. But there are some that do, although the differences are very subtle, and their systems are very sensitive to any changes. In my system I do hear just a little more presence in the presentation, I must emphasize, very subtle, but it’s there, between FLAC and AIFF. Between AIFF and WAV, I hear no difference at all. For those that do not hear any difference between any of this, I say don’t worry about it, it’s no big deal. FlAC is an excellent format also.
