Question when i play DSD Double (5.6MHz) in Roon using the Bridge II LAN output Roon is telling me that the hardware does not support DSD Double (5.6MHz) is this true, I’m running the new software ?
Brent
Brent
Yes that is true. The bridge only supports 64x (=2.8 MHz). The only way to play the 128, 256 or 512 without conversion is through the other inputs, preferably the I2S.
The DS can play DSD128 (i.e., double rate) over USB or I2S but not rates higher than that.
