DSD using USB input
Has anyone tride to make a single 2GB fat32 partition on a larger SD card? It might solve your problem cheaply. Take a look at this http://www.wikihow.com/Format-an-SD-Card
Thx for the quick response Ted. You were right as usual. I downloaded 1.2.1 and there’s an immediate audible difference between 1.1.9 and 1.2.1 as the dynamics are improved. I think I’m all set to do some A/B comparisons between the DS and the Antelope Zodiac Platinum using Redbook, Hi-Res and DSD tracks.
The rest of the system is as follows: VAC Phi 300.1a amp, VAC Renaissance pre-amp, Rockport Altair speakers, Synergistic Research Element CTS interconnects & speaker cables as well as the new Synergistic Research Galileo LE USB cable. Power cables are also Synergistic Research Element series. The front end is a Mac Mini with an external Oyen Digital disk drive connected via FireWire to the Mac Mini. Player software is Pure Music with up-sampling disabled.
Thanks to Ted, Stevem2 and everyone else in the DS Community for all your help.
Glad everything is working now.
