This thread is for discussing firmware updates, bug fixes and feature updates.
[Edit: -Ted Smith. FPGA 189 is available see
Thanks for this initiative; much appreciated!
Hereâs one thing that recently crossed my mind and that might be somewhat related: currently Roon recognizes the MK2 as a Mk1/generic âPSA extended resolution USâ. Which brings me to: is there a technical difference between the MK1 and MK2 as in how Roon recognizes the MK2 and adapts itâs rendering to the Dac?
If so, this would perhaps require a SW update and/or a renewed âhandshakeâ agreement with Roon to be âreadyâ.
If not, perhaps even better, but still it would be nice to see the MK2 being recognized by its (true?) name.
* web interface to control settings.* NOT WORKING ON.
Larger text display for both volume and format.
Hi, these ones have been flagged earlier on, but if weâre making a list of all the âto doâsâ for the DS2, Iâd like to suggest an update to the display settings so:
it can allow the user to choose a default of either giving prominence to the output / volume level, or the input name and its sample rate, so that in either setting, they are easily visible across the room; and
it can show the DS2âs pre-selected input names in full â At least on my unit, when using the coaxial input, the âStreamerâ input name shows up initially in large text, and then as âStreameâ in small text, together with the output / volume.
Already well discussed upgrades:
Most of those are being worked on.
I donât think thereâs currently a project for a web interface.
I know theyâve talked to Roon, but I donât know the status.
I donât know what #8 is.
Thanks Ted.
#8
Working on better sound quality in the SDM isnât going to happen until the next named release, perhaps 6 months or a year from now.
I would like a bit perfect test like we had with the mki.
That will be there. Iâve also added another file which can be used to configure the polarity of the I2S connections and probably also the configuration of the dual AES inputs.
Thanks Ted.
Yes. Itâs sometimes hard to tell when it is correct.
This is a very annoying issue.
Hopefully should be easy to fix, I suppose in my totally ignorance.
Please add me to the list of people who would like to have the âticks and popsâ issue addressed.
I now own a production unit of the MK2 â still within the 30-day return window â that has this VERY disturbing issue.
I havenât followed all the MK2 threads closely, but as far as I can tell, this noise happens when sample rates on selected tracks changes. Not only is the sound a horrible thing to hear, I worry about it blowing my speakers.
In my opinion, this is not minor and justifies an immediate fix.
I understand a clock matter is involved, takes a blip to go from one sampling frequency to another
And is there a solution to this?
allegedly in illusory firmware update in process last few months
akro: âallegedly in illusory firmware update in process last few monthsâ
And yet I have less than 20 days to decide whether or not this is a deal-breaking issue. Iâd like to think not, as the MK2 is a marked improvement over the DSD. But man⊠that noise is startling and disturbing.
