Directstream DAC MK2 - New Firmware 2.5.0
Hey everyone!
We have just uploaded the new firmware for the DSD MK2 onto the website here:
DSD MK2 2.5.0 Firmware and FPGA 208
The changes are in the release notes for the firmware in the zip file.
Thanks all!
If 2.3.6 was never installed, does it need to be installed first before loading the 2.5.0 files? Asking for a friend… :grin:
No, you can directly upgrade. There might be a small chance that a few options get munged, but nothing worse.
Excellent!
Running great here. Same recommended 100 hr “run-in” ?
Probably, the new code definitely uses a different pattern of guts of the FPGA.
Thanks!
Another member and I had our volumes stuck at 2 post-upgrade. The fix was to go to Audio Output and turn “fixed volume” off and “max volume” to at least as loud as you want to play (I set mine at 100).
