Firmware updates and fixes for the new Directstream MK2
For those following along at home, I seem to have been magically granted messaging functions, and all is well in the world. :slight_smile:
Thanks to all who offered help. Always appreciated…
I was able to download the zip file using Google chrome on my iMac without a problem. Double clicked on it and it unzipped instantly. Copied to a thumb drive and loaded into the MKII, also without a problem-listening to it now. Sounds great…I do think there is a subtle improvement in spatial representation. Thanks, Ted!
Elk GIFs - Get the best GIF on GIPHY
@tedsmith Ted, to simplify future firmware and FPGA updrades until wifi and ethernet upgrades are possible, I left a usb extension dougle out from the FW port in the back. Will this in theory affect the sound in anyway? i.e. noised picked up by the USB cable somehow getting into the system? Since MKII is so sensitvie.
Thanks!
My typical response is that that USB input is not connected to the hardware in a place that’s particularly close to things that will affect the sound quality. It’s hooked up to the control processor and not the FPGA, for example. I wouldn’t worry about it unless proven otherwise.
Hi Ted, did the latest FW update includes the auto shutoff on un-used HDMI or USB inputs? If not, will it be included in the next release?
The FPGA isn’t involved with powering up (or not) the I2S inputs or USB. The next UI update due in April will have those features.
I believe Paul said 4/10
That probably mean the real release date is around 8/10 or next year :laughing:
I know I am repeating myself, but I am guessing PSA wants to have a number of things fixed and/or released before AXPONA.
Personally, I want it to be release tomorrow, some the rough edges of UI is a bit too annoying considering how many smart devices with very user friendly UIs are available the market these days.
Can’t fault how the unit sounds, or I’d be more critical. I get PSaudio is more of a device component comany. Software, without proper talent, can be a challenge.
Indeed, based on experience, if not benchmarking, it would be asking a lot of PS Audio to have an OEM app that works multiple PS Audio devices. But web interfaces sure should be on their workplan. I was upstairs yesterday and wanted to turn off devices in the downstairs theatre. I was able to turn down, mute and turn off all devices except the PS Audio devices via my phone.
Patience waiting for firmware updates will pay off. Remember the 1st DS MK1 and how much the sound improved along with a better user interface in just the first year. I think we will be in for a treat when they release them. It gives me something to look forward to. I’m glad PS Audio released the MK2 when they did. I’m enjoying ours.
Just a note for those who haven’t yet done any FW upgrading on the MkII. The instructions state as follows (starting with Step 2 as Step 1 is not relevant to the observation):
  1. Insert the thumb drive into the USB Type-A port labelled FW on the back of the unit.
  2. Enter the menus (long press the menu button) and scroll right to the System sub-menu. Press the center nav button to enter the System sub-menu.
  3. Scroll right to the FPGA Load screen.
  4. You will see a list of valid FPGA files on the thumb drive. Highlight the one you want to load. In this case, you want to upgrade to fpga1_179_Antero.bin. Press the center nav button.
  5. A status screen will appear with details of the FPGA load process.
This suggests the MkII will automatically read to contents of the USB stick. For me at least, with the Sandisk stick I’m using (formatted to FAT32), this does not happen. I have to toggle power with the back switch, after which when it comes back on it will read the stick’s contents with no issue.
My MK2 sees the files every time I insert the USB. I can pull the USB, Insert it into my PC, copy files, EJECT, insert it into the MK2 and the new files shows instantly. This is just for Firmware files. For UI updates the update need to be on the USB stick, inserted into the DS then power cycle. The standby button will flash for about a minute and reboot.
Yes, I power off and back on. A very few times I got interrupted and when I got back it had read the USB stick without a power off and back on. But I don’t want to wait most of the time.
I think it depends on the size and brand of the USB stick. I never had to reboot mine. It showed up as soon as I inserted the USB stick. I have a small 8 GB USB stick.
I just wanted to point out that this isn’t something that can be taken as guaranteed, and that a small power cycle should fix it.
Yes, it is a common problem. And folks who have not experienced this can count themselves lucky. Cannot wait for OTA myself for the official updates. But happy to help test interim updates. My lucky stick of late is a 10-year old 3GB in basic FAT.
Have you tried a smaller USB stick? I have two 8 GB USB sticks and both of them are read instantly. Maybe the size of the USB stick is the issue??? Ether way it sounds like you have a good work around.
