This is a strange thread that seems to be missing the point of electrical isolation / grounding…
However, the readers of this tread must be aware of a few things not mentioned in the thread (sorry if I´ve missed it)
I think electrical isolation is a good thing. I had it on the USB-input on my Arcam D33 DAC designed ca 2011/12. Ted has raised the bar, isolating all connections. That said this thread is full of people complaining on not getting full effect, or gets added unwanted brightness.
Proper electronic isolation do not give full effect without proper grounding of high frequencies via draining it out of the equipment. You should get rid of brightness, it should add 3D, depth, flow, provide a sense of ease etc. I therefor write a few points with the intention of providing some more understanding of electronic isolation and grounding.
The way it is done by some users in this thread, you might isolate your dac, but hinder the dac from getting rid of high frequency noices that previously was sent from the dac via cables to other parts of the stereo. A small portion might have ended up in the power cleaner that usually drains all noice it can pick up to the earth ground.
A few thoughts
A) Changing ground takes time. Switching on off is hardly noticable. Any change should be evalutade at soonest 30 minutes after a change, with a maximum effect not expected prior to 24hrs. Stopping a lot of jitter and high frequency noice via electrical isolation can give a fast change and easily heard change, but the grounding part takes time.
B) Changing a cables ability to pick up noice and transfering it to a dac, does not make a stereo set up immune to ground noice.
- The DAC it self should also be grounded via something that sucks the noice created within the DAC out of the DAC (Entreq/CAD/others-boxes or minor sticks such as Chord GroundAray or Ansuz Sparkz can do the job)
- The DACs power-cable should direct incomming noice via the power cables ground cable away from the DAC (Audioquest Storm-series power cables does this)
- The rest of the stereo, including speakers and power regenerators might benefit greatly from grounding inputs/outputs or chassis (power plats should be grounded in the chassis) connected to an external grounding box.
The subject of electrical isolation and transferering high frequency noice via electronics and cables are closely related to the topic of grounding hifi in more ways than just putting the power cable in a grounded wall outlet.
This was my 2 cents to help getting rid of that “brightness” people write about in this thread. The DAC Mk II should in theory improve sound when isolation is used, but it is more to it.
If even one owner of the new dac gets better sound after reading this, I´m more than happy.
PS: Do not forgett to listen with the same ground in your body as your stereo, then things start to bloom even more…
