Headphones for $3K
Hi all,
I am about to buy my first set of headphones and am after some advice.
Looking at spending $3K.
Looking at maybe Meze Empyrean.
I am a Stellar Gain Cell Dac.
What I want to know is willl the SGD have the power to run these?
Cheers
Andy
Hi Andy,
$3k USD for a set of headphones gives you a lot of options. What is your most important attribute for a headphone? Personally, I would not spend the asking price (3K) for ‘regular’ Empyreans. If you are set on the Meze brand, I would look for the Empyrean Elites instead. Last fall, imported Chameleon edition Elites were going for 3.2k USD. Granted, the euro was weaker then.
I believe PS Audio have stated they used Audeze headphones in the past to voice the HP outs of their gear, but I am not sure which models. The new LCD-5 can be had for around $3k with a bit of luck.
The SGD should be able to power most headphones, save for the outliers like HE6-SEv2, etc.
If memory serves PS Audio used the LCD-X with the BHK Pre.
@Andy_Walters i have no experience with Meze cans, but they have a few Open Box discounted Empyreans at TMR.
Similar to CarbonF1, I just bought a pair of Meze Elites from Headphones.com as an ‘open box’ for $2999. There isn’t a scratch on them. I’ve seen the Elites on other sites in ‘open box’ offerings for $3200 (check out Roon’s store).
I’ve owned Audeze LCD-XCs for 7 years. As much as I like the sound of those I couldn’t wear them for more than an hour. As the years went on I found I was far more sensitive to their weight and would be hard pressed to wear them 30 minutes. The Elites have a different sound, less high end, smoother, but just as pleasing to my ears. But best of all I literally sit in my home office and listen to them hours on end without the least bit of head fatigue. They’re just so comfortable.
Look at some of the Open-Box offerings, you can get these for pretty close to the $3K you’re willing to spend on the Empyreans.
Good Luck!
Is it the particular sound of Meze that you’re interested in? If so I agree 100% with the above comments. If you’re worried about ease of drive, the Focal Stellia can be had from TMR at well under your budget and is super easy to drive with excellent detail.
I am a headphone fan. I don’t mean to dissuade you, unless you are planning to get a separate headphone amp to hang off the SGD down the road, the SGD isn’t quite up to the task for getting the best out of $3K headphones.
Have you looked at the Sennheiser 800 S, Focal Clear, or the Hifiman Arya V2? There’s lots in the ~$1500 range.
There’s also some awesome IEM’s in this range:
Before I joined this forum I was on the Headroom forum. I could stock a store with my headphone collection. It was my thing for a long time. I have given many away just so they get used. But my favorite all time headphones are a $140 pair of wireless Ankers. I use them 3 hours a day on average. Six hours on the drive down here. Six hours on the ride home. They are my precious. Gollum Gollum.
$3000 headphones are just silly. What next, power cables and fuses??!!
You can better buy a decent headphone amp in combination with a Beyerdynamic DT1990 or a Sennheiser HD660.
Agreed. Any of the Sennheiser 600 series. Absolute classics. My first two headphones were a Jecklin Float 2 and an HD600. Fond memories and regretted sales.
What’s sillier, $3K headphones or a hyped new $8K DAC that turns out to need a $5K mystery box to hook it up to your network?
bravo
I have three headphones that I use and would recommend as they are so darned good sounding.
Sennheiser HD800S
ZMF Ori
Oppo PM-1
The Ori and the PM-1 are no longer made, but I’ve seen them available fairly recently second-hand or old stock.
Hi All,
Just letting you know I am going to pull the trigger on a pair of Meze 109 Pro cans,
Thoughts?
Cheers
Andy
Have you had a chance to listen to the Abyss 1266 Phi TC headphones? They are my all time favourite so far.
I have not. I walked through the headphone room. And I SHOULD HAVE listened to many headphones but I didn’t. Doh!
One of the guys at work recently bought a pair, he really likes them. He said they are the most comfortable headphones he’s ever worn. Meze has an awesome reputation.
@vkennedy61
How much do I need to spend on an amp?
Cheers
Andy
If we stay in your budget, I think it’s not unreasonable to split your budget in half and spend $1500 on headphones and $1500 on an amp. You can get quite a lot of bang for your buck if you look for a used $1500 amp.
If you use the filters in this search, make sure you choose N. America and set a price range like $1200 to $1800. There’s a lot available.
And don’t forget headphone cabling. I find they make significant differences.
@lonson Can you suggest a cable for the 109’s?
Cheers
Andy
