Currently I have 3 different brands running. I am planning to change my Lorex system out for Ubiquiti system. Unifi hardware is quite an upgrade, the camera body heft , the light sensor capture, the optical zoom. I like how they’re software works. They have an adapter that allows the customer to transition they’re current camera over to the Ubiquiti system, but I won’t be taking that route. I will start with one ptz camera on they’re nvr and I have a new seagate 16TB drive that I have laying around collecting dust. I will also need to get they’re long range switch where I will have poe++ .
All I have is Ring light and camera setup, they are alright.
Don’t know about their cameras, but Ubiquiti makes top notch networking hardware.
I have two Unifi systems (two locations) for going on two years. Can not recommend them highly enough. Zero issues except that at one location, I occasionally need to reboot the WiFi to get Roon remotes to see the main unit. Not been enough of an issue to warrant seeking a fix, Could be network settings or that one site has a Mac mini as the Roon server and the other a nucleus one. Zero Unifi hardware issues. There is an “protect” app that I use on an Apple TV that lets me view all of my cameras remotely off site. Save those little levels. They are accurate (simple check for any bubble level: just rotate it 180˚ end-to-end and it should read the same. Endless uses-almost no added weight to set on the tonearm shell to check its level; glued to stick on window bird feeder to make reinstallation easier after cleaning. One big advantage to unifi protect is that I know my camera feeds only go where I want them to. Who knows what happens with, e.g. Ring cameras.
I like it, thanks for sharing that.
I have concluded what I need and I will keep my Lorex running but remove only one camera which is the front in my carport, which guards my cars and which will record a corner across the street where unwanted things may occur. The reason for using Unifi G6 Pro is its properties for low light excellence and license plate recognition. I am guessing that when I get it up and running that at night I won’t need the ir to run at all.
