Sounds similar to white noise, very loud. Happens only when playing hi res DVDs on the PWT.
It occurs when a new track is selected but only once in a while.
After the second time it happened on its own I was able to duplicate it.
With the volume set very low I played a hi res DVD and just hit the skip button over and over till it happened. I would estimate it occurred about 2% of the time.
I’ve seen that rarely if you change tracks multiple times quickly - and never if I don’t. I have an older PWT for debugging and don’t know if it’s typical.
I assume this a DVD to which you burned high resolution files. It may because the files are on the disk as data files, without Redbook or other media book formatting.
There is no “standard” tagging for WAV files. If you don’t want to use FLAC you might convert them to AIFF. WAV and AIFF are very similar (same data, different headers). I play tagged AIFF files up to 192/24 over the Bridge with no problem.
