I’ve upgraded the device a few times and have lost track. It started out as a PWD and has been added to more than once.
what is the easiest way to check? Thanks
Pull the bridge out, and if it has a daughter card on it, it is a bridge II. If it does not it is a bridge I.
Dennis
Groan. Will do. Dragging audio gear out of racks is grim. I’d hoped you had a programmer like C3PO.bin
What is the version of bridge code? if it is 0.2.15 it is a Bridge I. If it is 1.2.3 or 1.2.5 or 2.7.11 it is abridge II.
Dennis
Much easier. I have “Bridge Version: 0.2.15a”, so a 1 and it explains why Roon wasn’t finding the unit.
mine is 13-057-01-1. Rev.C.
any idea what model is it?
