Hi All
On Saturday we tuned into JRAD that was being streamed on the Twitch mobile app. We were not able to figure out how to connect it to. Can anyone share how to do this for Twitch?
Many thanks in advance!
Hi All
Unfortunately the Strata is only capable of accepting streams from certified sources such as Spotify, Tidal and Qobuz. You can still stream to the unit but it would need to be done over USB from a computer.
Ok, thanks for your honest answer. Can always stream to a Bluetooth device connected via optical to the Strata. Sound quality won’t be great but I don’t think Twitch is high fidelity.
Yeah you’re probably right, you might not actually lose too much going over Bluetooth.
