Anyone compared the DSD with the Bridge & with it removed? I’m using the USB input.
Thanks,
Kev
If you are using USB as your input, I suggest removing the Bridge. However, you can form your own conclusion by letting your ears be the judge by comparing the sound with, and without the Bridge installed.
There has been a lot of discussion surrounding this topic (Ted himself, included), and the consensus seems to be that the Bridge can be a source of noise. Noise is bad. If not using the Bridge, then why take the chance?
