I came across a pair of Infinity QLS-1’s, completely restored by a person well versed in speaker engineering and restoration. I’m considering making an offer for them, but I’m hesitant. I own the Stella GCD and M700’s and would like to know if they are an appropriate match for such speakers?
I wouldn’t be playing them more than moderately loud and fully realize that they need a lot of wattage to get them moving. Since Paul is using the big brother on steroids version of what I currently own, would acquiring the QLS-1’s be a bad/ok/good match for my gear?
Has anyone out there had any experience with these speakers?
Here are some of the specs:
QLS-1 Quantum Line Source Series 4-Way Speaker
ACOUSTIC & ELECTRICAL SPECIFICATIONS:
Nominal Impedance: 4 ohms
Power Rating: 100 watts RMS Minimun
Crossover Frequencies: 200, 600, 4kHz
Frequency Response: 18Hz-32kHz +/-2dB
NOTE: Woofer has dual voice coils, solid red wire is 4 ohm pos.,
solid black wire is 2 ohm pos.
PHYSICAL SPECIFICATIONS:
8x - EMIT Tweeters, 4 through 32kHz
6x - 1-1/2" (3.8cm) Dome Midrange, 600Hz to 4 kHz
1x - Midbass Coupler, 200 to 600Hz
1x - 12" (30.5cm) Infinity/Watkin Dual-Drive Woofer, 18 to 200Hz
Dimensions: 5-1/2’H x 15"W" x 18"D
Regards,
Mark
