I would like to install the NPC about 15 meter remot of the destination of the Output-signal ( eather Analog or digital). The
destination will be my psaudio DAC or a “room-equalizer” called AUDIOVOLVER.
Question: Would this distance reduce the quality of the Output. What type of cable is recommendable for a digitalout?
With regards, Egon Winkelmann
in Wildhaus-Switzerland
egono@hotmail.ch .
It would sure not be my first recommendation to go analog but if you can go digital, you might be ok. A 15 meter coax of good quality to the DAC might work alright and probably worth a try. A 15 meter analog cable, balanced, is surely going to degrade the signal but can be done.
Welcome, Egon!
Please let us know how the NPC works out for you.
I am still waiting for the delivery of the NPC from the german dealer. I will Report after Installation.
With regards, Egon.
