Im a bit short on space and am wondering if stacking is OK, if so which would you put on the bottom?
Thanks, Mark
Thanks, Mark
It’s perfectly okay. Personally, I’d put the DirectStream on top, but I’m not sure there’s a sonic difference.
In fact you can unscrew the feet on the top one and they fit together nicely - almost like PS Audio did it on purpose ![]()
I recall reading in an earlier discussion about this that the feeling was to put the PWT on the bottom.
Thanks for replies all!
